molten plastic
Old   May 6, 2004, 03:46
Default molten plastic
Koh
Would like to enquire if molten plastic is classified as a non-newtonian fluid.
Need to model some form of plastic extrusion molding in COSMOS FloWorks. So far I've just been using some value for dynamic viscosity.
Thank you.
Old   May 7, 2004, 03:27
Default Re: molten plastic
Thierry
Plastics and polymes are complex materials (the polymer molecule is a very long chain, nothing similar to water or air). This could induce some non-isotropic behavior known as viscoelasticity leading to large die swell. But without going that far, neglecting the shear thinning behavior of the plastic will strongly impact the accuracy of your results especially for the extrusion process where shear thinning is p-laying a major role. Non-Newtonian behavior and more specifically Generalized Newtonian behavior could have the viscosity decreasing by several orders of magnitude, therefore affecting the pressure drop no mentioning the flow pattern. I would strongly encourage you to involve such behavior. Simple models like the power law or better the Bird-Carreau law are already doing a good job.
I hope this helps
Old   May 10, 2004, 09:12
Koh
Hi Thierry, thank very much for the input. It certainly does help.
Fortunately COSMOS FloWorks does include the power law and Carreau models for non-newtonian flow.
Thanks again.
Rgds, Koh
Thread Tools
Trackbacks are On
Melting Aluminum by molten Stell leff Main CFD Forum 0 May 17, 2011 04:12
Modeling plastic injection process in CFX. psicosis_x CFX 2 April 13, 2011 14:04
joining plates (metal and plastic) with laser welding. visagant Main CFD Forum 0 November 5, 2010 11:26
Molten solder jet Sunchai Main CFD Forum 0 June 3, 2009 11:49
A simple plastic solid model in FSI jinwon park Main CFD Forum 7 April 30, 2008 05:05
