April 17, 2010, 04:24 |
under relaxation & Periodic Flows
Ardalan
Rep Power: 16 |
-What is the difference between under-relaxation and false time step? What are the advantages and disadvantages of each one?
-For problems which have a steady state we stop calculations when time derivative is zero. What about periodic flows for example flow past a circular cylinder? |
April 17, 2010, 06:55 |
Tanmoy
Rep Power: 16 |
under relaxaation scheme is a power scheme during Iteration.I have used it in FDM ,but widely used in FVM.good for retarded convergence.yet stable.When periodically motions are there no decay solutions with respect to time will observed.dont know about false time step..know about false diffusion!
April 17, 2010, 11:55 |
Dear friends:
For steady problem, when we use the unde-realxation, you can find that the discretized equation is equivalent to the unsteary problem. |
April 17, 2010, 13:13 |
ganesh
Rep Power: 17 |
Dear Ardalan,
Under relaxation is generally employed when the code shows a tendency to diverge and is therefore more a stabilization tool. False time or pseudo time stepping actually is a convergence acceleration procedure, where ideas from steady--state solvers can be employed for a genuinely unsteady problem. It is possible that solvers might use both these concepts. For periodic problems, as the name suggests we stop the code when a periodic state is acheieved, in other words, the mean of integrated coefficients like Cl and Cd are invariant with time. Regards, Ganesh |
April 18, 2010, 00:43 |
L.Y LIN
Rep Power: 16 |
above masters,where could i find some books about these tow concepts?i really want know them,thanks!
Periodic boundary condition | Arif | FLUENT | 3 | March 9, 2017 01:18 |
periodic flows | Phil | FLUENT | 14 | May 16, 2013 07:21 |
Relaxation and convergence | sammi | Phoenics | 0 | March 20, 2008 03:32 |
Question on adjusting relaxation factor | CFD Rookie | Main CFD Forum | 3 | January 26, 2004 14:37 |
periodic flows and heat transfer? | scarecrow | FLUENT | 3 | December 2, 2003 00:59 |
