version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found
I have installed OpenFOAM in my directory on a cluster. I have also been able to run an interactive parallel computation. However, when I try to run a batch job using a PBS script, I get the following error message: blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by blockMesh) blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ba01/u125/edoro/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libmeshTools.so) blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ba01/u125/edoro/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicMesh.so) blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ba01/u125/edoro/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so) blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ba01/u125/edoro/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libtriSurface.so) blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ba01/u125/edoro/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libdecompositionMethods.so) blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ba01/u125/edoro/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/liblagrangian.so) blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ba01/u125/edoro/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so) blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ba01/u125/edoro/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/mpich2-1.1.1p1/libPstream.so) blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /home/ba01/u125/edoro/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/mpich2-1.1.1p1/libPstream.so) The message is the same for all the other OpenFOAM commands, such as setFields, decomposePar, reconstructPar etc. My installation uses the ThirdParty gcc supplied with OpenFOAM although I initially used the system's compilers but changed it when I had some errors after running foamInstallationTest. The system runs on MPICH and not OpenFOAM's OpenMPI. I have tried to create and rename the symbolic link by doing: cd /home/USER_NAME/OpenFOAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux64/lib64 mv libstdc++.so.6 libstdc++.so.6.orig ln -s /usr/lib/libstdc++.so.6.0.8 libstdc++.so.6 But I still get the error messages. Could someone please help? Thanks Ovie |
I am sorry I should have post this in the OpenFOAM forum.
My apologies. Ovie |
