Need your opinion
Old   May 4, 2004, 15:19
Default Need your opinion
jason
Hi..there,
I need your opinion about what I'm thinking
The turbulent viscosity can be written using the low k-e model like this nu_t=cmu*fmu*k**2/e fmu : dampling function cmu : constant value from standard ke model.
Generally, the dissipation term is calculated from the trasport equation.
But, I'd like to use only the one-equation to make the turbulence model.
if we adopted the mixing length for e, we can write e=k**(1.5)/lm lm: the mixing length of Van Driest
Finally, the turbulent viscosity is nu_t=cmu*fmu*(te**0.5)*lm..
Is this resonable to compute the turbulence values with Navier Stokes equation? Is there any mathematically discrepancies in this one-equation?
Please, tell me anything about this question Have a nice day
Old   May 4, 2004, 16:14
Default Re: Need your opinion
Hrvoje Jasak
It's OK, you are allowed to do that. The question is where you are going to get the distribution of the mixing length. If you can guess it correctly, there's no need to solve an equation for it. However, guessing the mixing length is not easy and will depend on the case you are trying to simulate.
Hrv
Old   May 8, 2004, 00:21
Default ReQuestion
Jay
Thank you for your help,
What do you think if I use lm as Cebeci-Smith length model or lm(l_e) from Norris and Reynolds's damping function under a near wall region (z+=around 100)?
lm=cappa*z*(1.-exp(-z+/a) from Cebeci-Smith model
or
lm=Const*z/(1.+5.3/Re_z) from two-layer model
which is more reasonable to compute the turbulent viscosity and turbulent kinetic energy?
Jay
Opinion on Powerflow a CFD user with some Powerflow experience Main CFD Forum 6 April 17, 2003 05:18
Opinion about CFX4 and CFX5 Jan Rusås CFX 17 August 17, 2002 16:28
Your valuable opinion is needed R Amini Main CFD Forum 6 December 11, 2001 17:54
FLUENT- your opinion Chatterjee Main CFD Forum 4 August 8, 2000 12:56
Expert Opinion Rooh-ul-Amin Khuram Siemens 14 July 15, 2000 19:43
