How to make pipe flow in 2D?
Old   April 25, 2010, 23:23
Default How to make pipe flow in 2D?
Park HyunChul
ufirsthc is on a distinguished road
Software : Gambit -> Fluent
Hint) Use axisymmetry in Solver
is it impossible?
ufirsthc is offline   Reply With Quote
Old   April 27, 2010, 01:29
Hamid Zoka
Hamidzoka is on a distinguished road
Hi;
you can model a 2-d pipe flow using axisymmetric solvers.
please note that all equations should be set in cylindrical reference frame. in this case your variables are only functions of R and Z.
you need to define a rectangle as the following.
-left side will be inlet
-right side will be outlet
-upper side is wall
-lower side is axisymmetric or mirror.(depending to the software you use).
lower side is in fact center of the pipe.
Hamidzoka is offline   Reply With Quote
Thread Tools
Trackbacks are On
High speed compressible flow through pipe Munni Main CFD Forum 6 December 7, 2015 12:33
flow in perforated pipe distributor pertupd ANSYS 0 August 12, 2009 08:36
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 05:04
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
