Gambit: creating volume from a group of faces |
April 30, 2010, 06:07 |
abdolreza fazeli
hi
I try to do an optimization process on a heat sink using Matlab which calls fluent and gambit. In fact, I'm optimizing the number of channels in a microchannel heat sink. but the problem is that i have to create a volume in gambit with unknown number of faces (which is interface of microchannels with the base metal of heat sink) I mean, using gambit and "stitch" command, you have to call all the faces at once and as i duuno how many faces i have, i' quite stuck. i dunno what to do, i've tried creating group of faces but then i saw that i cant create volume from groups and DO LOOPs are not useful here either. Please help me through I appreciate any comments |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Converting Virtual Faces to Real Faces in Gambit | gstraw | Main CFD Forum | 0 | June 19, 2009 07:11 |
Gambit meshing error | jx | FLUENT | 11 | May 26, 2009 10:35 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
