Vertical pipe flow
Old   May 21, 2004, 16:13
Default Vertical pipe flow
Saud
I have this modeling question: I am trying to understand the effect of that will result in a body-like force in the axial direction (only) downward due to a magnetic field on a steady state vertical pipe flow. What would be the most appropriate inlet and boundary conditions That will lead for the exit flow rate as part of the solution.
I thought of prescribed inlet and boundary pressure condition defined as the head (rho*g*h)
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 10:14
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 04:04
Domain for Pipe Flow Swarup FLUENT 0 September 28, 2005 23:25
outlet boudary condition for a flow in the pipe Atit CFX 2 November 9, 2004 17:43
