heat equation solution source code
Hi all,
I look for a source code in C++ or Matalb which solves the time dependent 2-D heat conduction equation in a square section for a given BC and IC using finite difference method and finite volume method. I prefer a code which uses SOR and Crank-Nicolson scheme. Anyone has a idea where can I find examples or related source codes ? Thanks in advance, John |
Re: heat equation solution source code
Hi john,
I have written a code for this 2-d heat conduction equation(unsteady)using ftcs scheme. I have written the code in "VISUAL BASIC". Will this be helpful for u? bye jyo |
