flow rate in vertical tube
What would be the most appropriate inlet and outlet boundary conditions for an incompressible steady state flow in a vertical tube. The flow rate is sought as part of the solution.
I tried inlet zero refernce pressure and a free fully developed oultlet condition but with no success. Your kind response is appreciated. |
Re: flow rate in vertical tube
For inlet: velocity is prescribed, pressure is extrapolated from interior, For outlet: Pressure is prescribed, velocities are extrapolated from interior. Try above BC.
Versi, You Kindly responded: "For inlet: velocity is prescribed, pressure is extrapolated from interior, For outlet: Pressure is prescribed, velocities are extrapolated from interior. Try above BC."
But I thought prescibing velocity at the inlet (or exit)implies prescibing the flow rate itself for such steady state simulation. I am looking for BC's that will lead to the flow rate as an output results not as an input. What do you suggest. Thanks |
