Angle of Attack (AoA) adjustment for 2D / 3D
Old   May 10, 2010, 08:21
Question Angle of Attack (AoA) adjustment for 2D / 3D
Mitch Greenberg
FractureProof is on a distinguished road
Hi, I have about 20 years of structural / stress analysis experience, however I am just diving into some CFD research to create a realistic aircraft to base a training course around.
I have gone through some simple tutorials for using FLUENT from Cornell:
http://courses.cit.cornell.edu/fluent/airfoil/step4.htm
In which, the objectiv eis to model a 2D NACA airfoil section at 2 deg AOA. In the process, it states "(Note that 1.2° is used as our angle of attack instead of 2° to adjust for the error caused by assuming the airfoil to be 2D instead of 3D.)"
I imagine this is maybe due to vortex shedding.. but I'm just guessing... Can someone detail this requirement and provide link to allow me to calculate this adjustment for arbitrary AoA. Thx.
FractureProof is offline   Reply With Quote
Old   May 10, 2010, 08:39
agd
agd is on a distinguished road
If I remember correctly, it is actually due to the fact that in a 2D simulation, there is no third dimension for the flow to move in. In 3 dimensions the angle of attack has to be slightly higher to get the same effective momentum change for lift because some of the flow can move out along the wings. John Anderson has a good basic Aero book (whose title escapes me now). Katz and Plotkin also have a good book on low speed airfoil theory, but again the title escapes me and I am at work while my books are at home. You could also try googling low speed airfoil theory or potential theory for airfoils.
agd is offline   Reply With Quote
adjustment, angle of attack, aoa
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
introducing angle of attack on ICEMCFD HEXA icem beginner CFX 2 December 24, 2008 11:00
introducing angle of attack on ICEMCFD HEXA icem beginner FLUENT 2 December 6, 2008 15:34
angle of attack with icem hexa icem beginner Main CFD Forum 0 December 5, 2008 16:54
angle of attack kiran FLUENT 0 September 10, 2004 08:18
