Radiation and Symmetry
Old   May 31, 2004, 09:25
Default Radiation and Symmetry
Eric
Hi all,
Can anyone tell me if the radiation models are realiable when using symmetry?
As the radiation models are based on reflection, can fluent account for radiation that may cross the symmetry axis? For example a cylindrical furnace using symmetry along the longitudinal axis.
Thanx
Eric
Old   May 31, 2004, 10:02
Default Re: Radiation and Symmetry
Rami
Eric,
I cannot comment about fluent treatment of symmetry for radiation as I have never used it. However, any radiation solver implemnting specular reflection may be used to simulate symmetry. Symmetry surface is merely a perfect specular reflector. For the axis of a cylinder, the approach I use (FVM) naturally treats this zero area surface (any finite flux results in zero power for zero surface area).
I hope this helps,
Rami
Old   June 3, 2004, 06:55
nuray
Radiation models solve intensity(I) for each grid point and direction. if possible, print the intermediate intensity values in the domain for a sweep. If symmetrical boundary condition is implenmeted correctly, at the symmetry axis incoming intensity should be equal to out going intensity with a different sign. Here is the bc
I_m = I_mī
where m : incoming direction
mī: outgoing direction
There are simple test cases available in the radiation heat transfer books for cylindrical media.
Quickest way: Radiation model provides source term to energy equation. if you donīt see any non-symmetric temperature profile along z axis it means that it works.
Nuray
Old   June 3, 2004, 07:30
Default Thanks nuray and Rami
Eric
error radiation model monte carlo andro Main CFD Forum 1 February 2, 2012 09:20
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
Incident Radiation Nicki CFX 1 April 17, 2009 08:18
radiation and symmetry Mark FLUENT 2 November 4, 2004 13:50
Radiation and symmetry Eric FLUENT 2 May 31, 2004 11:02
