Estimate turbulence dissipation rate (epsilon) |
May 12, 2010, 18:52 |
Rep Power: 16 |
hi,
i have to following question: I want to simulate a hot gas jet exaust of a pipe into a colder freestream (hot streak in a gasturbine). What i have from measurement is a 45x45 grid and the data for each node is: - velocity u - velocity v - velocity w - turbulent kinetic energy - turbulent intensity [%] - total pressure - total temperature How can I estimate epsilon in order to use the measured turbulence kinetic energy as an Inlet boundary Condition in ANSYS CFX? The shear of the hot gas with the colder freestream has to be modeled as accurtate as possible... any suggestions? Thank you very much!!! |
May 12, 2010, 18:54 |
Rep Power: 16 |
forgot to say:
x is the streamwise direction and I want to use k as a profile BC for ANSYS CFX. Does epsilon has to be also a profile (for each node different) or can one assume a constant value over the whole inlet? Thank you |
Display Modes | |
CFX12 rif errors | romance | CFX | 4 | October 26, 2009 13:41 |
turbulence dissipation rate in DNS | Shaohua Wu | Main CFD Forum | 0 | September 16, 2008 23:11 |
turbulence eddy dissipation rate | panneerselvam.R | CFX | 0 | August 25, 2005 04:51 |
how to decide boundary condition of turbulence energy dissipation rate? | Vincent B. | Main CFD Forum | 5 | October 28, 1999 04:07 |
