May 15, 2010, 11:51 |
AVL fire Exhaust manifold Simulation
Mohsen Khalafi
Rep Power: 15 |
hello every body
I have been using AVL fire as my CFD tool for some years now and I have done some simulations with it. right now I'm trying to simulate the exhaust flow through a Diesel engine manifold for some Heat transfer calculations and since the engine is turbo charged the mass flow is a bit high and the flow is around mach 0.3. my problem is that i can't get a converged solution and i should say that i'm doing a transient simulation over an exhaust stroke. I use AVL boost mass flow and temperature results as boundary conditions on inlet and my outlet is simply a static pressure with a non fixed temperature boundary. walls are just fixed temperature and the mesh quality i think is pretty good.my problem is that all my simulation diverge after some some time steps which each of them is like 1 Crank angle as the engine is at 2500 rpm. I would really appreciate if any one could help me on this case and would love to have discussions on IC engine oriented simulation with AVL fire. Thanks guys |
avl fire, exhaust manifold, ic engine |
AVL fire CI engine simulation neeed HELP ! | Mohsen khalafi | AVL FIRE | 1 | September 10, 2018 10:32 |
NEED HELP on IC engine simulation with AVL FIRE! | Mohsen khalafi | Main CFD Forum | 2 | February 6, 2014 07:47 |
exhaust manifold flow and heat transfer simulation | jai | CFX | 4 | September 6, 2013 15:52 |
Exhaust Gas manifold simulation | shrinath | Siemens | 6 | September 5, 2013 16:26 |
AVL Fire transonic simulation | Ainil | Main CFD Forum | 1 | August 24, 2010 15:53 |
