AVL fire Exhaust manifold Simulation
Old   May 15, 2010, 11:51
Default AVL fire Exhaust manifold Simulation
Mohsen Khalafi
mohsenfjs is on a distinguished road
hello every body
I have been using AVL fire as my CFD tool for some years now and I have done some simulations with it. right now I'm trying to simulate the exhaust flow through a Diesel engine manifold for some Heat transfer calculations and since the engine is turbo charged the mass flow is a bit high and the flow is around mach 0.3.
my problem is that i can't get a converged solution and i should say that i'm doing a transient simulation over an exhaust stroke. I use AVL boost mass flow and temperature results as boundary conditions on inlet and my outlet is simply a static pressure with a non fixed temperature boundary. walls are just fixed temperature and the mesh quality i think is pretty good.my problem is that all my simulation diverge after some some time steps which each of them is like 1 Crank angle as the engine is at 2500 rpm.
I would really appreciate if any one could help me on this case and would love to have discussions on IC engine oriented simulation with AVL fire.
Thanks guys
mohsenfjs is offline   Reply With Quote
avl fire, exhaust manifold, ic engine
AVL fire CI engine simulation neeed HELP ! Mohsen khalafi AVL FIRE 1 September 10, 2018 10:32
NEED HELP on IC engine simulation with AVL FIRE! Mohsen khalafi Main CFD Forum 2 February 6, 2014 07:47
exhaust manifold flow and heat transfer simulation jai CFX 4 September 6, 2013 15:52
Exhaust Gas manifold simulation shrinath Siemens 6 September 5, 2013 16:26
AVL Fire transonic simulation Ainil Main CFD Forum 1 August 24, 2010 15:53
