Floworks & Aero
Old   June 7, 2004, 15:13
Default Floworks & Aero
BW Malcolm
I have been "playing" with doing some aircraft modeling using Floworks 2003. I find it extremely easy to use & have run a few simple models such as 2D flow past a cyl, etc. The flow fields look surprisingly close to expected & the force answers are at least in the ball park of experimental data.
However, when I try running either a 2D or 3D wing section, the forces (especially lift) do not seem to be even close.
The most obvious suspected problem is user error in interpreting the input or output, but if that is the case, this user is stumped. Has anyone done a good wing validation model with Floworks they would be willing to share?
Or recommendations from the group on the suitability of Floworks or recommendation of other CFD packages for aero analysis? I am not looking for "exact" solutions - just ones that can provide good first order solutions for comparing configurations.
Thanks!
Old   June 7, 2004, 15:44
Default Re: Floworks & Aero
Jarmo Monttinen
I don't know anything about Floworks..
What do you mean that you are in the ball park of experimental values for cylinder? At what RE?
For wings and airfoils: what is your Reynolds number, angle of attack and so on? Do you get zero lift for a symmetric shape at AOA = 0?
-- Jarmo
Solving a NACA0010 in Floworks magicroot FloEFD, FloWorks & FloTHERM 1 March 23, 2011 06:18
Cross Axial Rotation problems with FloWorks jacobjb FloEFD, FloWorks & FloTHERM 2 March 8, 2010 14:20
Start with FloWorks ironman FloEFD, FloWorks & FloTHERM 1 March 3, 2010 20:34
Physical correlation to FloWorks for air ducting Matt Quinn FloEFD, FloWorks & FloTHERM 2 December 14, 2009 10:58
New dedicated forum for EFD and FloWorks users Forum Administrator Main CFD Forum 6 April 15, 2008 11:56
