May 25, 2010, 15:26 |
Genetic Algorithm
Morteza
Rep Power: 15 |
Hi .. I am lookin for a genetic algorithm code for transonic airfoil optimization, anybody can help me???
May 27, 2010, 05:51 |
Björn Bergqvist
Rep Power: 17 |
http://opt4j.sourceforge.net/
I've set up an optimization case for discretizer+openfoam: http://www.discretizer.org/files/opt...utorial.tar.gz Björn
________________________________________ Björn Bergqvist, creator of Discretizer, a free mesh generator for OpenFOAM _________http://www.discretizer.org_____________
May 27, 2010, 14:27 |
#3 | |
Morteza
Rep Power: 15 |
May 27, 2010, 14:37 |
#4 | |
Morteza
Rep Power: 15 |
could you plz tell me how can i find a tutorial for airfoil optimization? is this software open source? |
May 27, 2010, 14:59 |
Björn Bergqvist
Rep Power: 17 |
Maybe you can use your imagination? Probably all airfoils are optimized?
Most important is to be able to set up a HUGE function. INPUT => HUGE FUNCTION(CFD-analysis) => RESULT So basically, create a script with a couple of input arguments. Suppress all stdout messages except the result at the end :-) Possible way of solving it(free software path): 1. use gmsh for geometry creation, create a surface mesh 2. use snappyHexMesh for volume mesh creation 3. use OpenFOAM for CFD-calculation 4. get the output from force monitoring via scripts Use opt4j or Dakota as optimizer. The commercial path: 1. Ansa for geometry and surface mesh creation (via morphing) 2. Star-CCM+ for volume mesh and postprocessing (via java scripts) Use ModeFRONTIER as optimizer. Björn
What is advantage of SIMPLE algorithm? | Geon-Hong | Main CFD Forum | 1 | May 18, 2010 07:46 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | Main CFD Forum | 0 | April 18, 2007 03:48 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | FLUENT | 0 | April 13, 2007 23:17 |
mach-uniform algorithm for LES/DNS | ilyas | Main CFD Forum | 0 | February 22, 2007 10:53 |
CFD algorithm design with reconfigurable computing | BeatrÃz Navarro | Main CFD Forum | 1 | June 25, 2006 14:25 |
