WALL FUNCTION: Implement process
Old   May 21, 2004, 01:58
Default WALL FUNCTION: Implement process
boling2002
I am currently working on implementing the wall function to Wilcox wall function.Now I am trying the case for flat plate. My code is using JST scheme. The main steps I am using are: 1) Compute u_{\tau} by using y^{+}=1/k ln( u^{+} + B with given velocity from the first interior cell. 2) Compute \tau_{w} using u_{\tau} and \rho. 3) Using the integral x-component of \tau_{w} multiply the maginitude of surface vector. 4) Set the engergy item to zero since I am working for steady adibatic case.
Is there anything wrong in my implementation, I could not get the resonable results. Could anyone give me your hand ?
Thanks
Old   May 23, 2004, 17:55
Default Please help me.
boling2002
thanks .
Old   June 8, 2004, 09:32
Default Re: WALL FUNCTION: Implement process
Jonas Bredberg
Hi there,
I guess you simply forgot to tell us that you have included the following functions for k and omega: k=u_tau/sqrt(C_mu) omega=u_tau/(sqrt(C_mu)*\kappa*y) Furthermore it seems to be a typo for the log-law: u+=log(y+)/\kappa+C, \kappa=0.41, C=5 When computing u_tau (from the log-law and u+=U/u_tau) you could maybe iterative some times, as the log-law needs y+ which involves u_tau itself as: y+=u_tau*y*\rho/\mu What you mean by multiplying tau_w with the surface vector, and don't know. Though I guess you do it rightly. Tau_w is the surface tension which is introduced in FVM as a source term by multiplying with the appropriate surface-area.
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Need some wall function approaches! yka8150 Main CFD Forum 0 September 21, 2009 23:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Wall function problem in Fluent mefpz FLUENT 1 October 10, 2007 13:43
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
