Channel Flow Development Length
Old   May 8, 2010, 11:16
Default Channel Flow Development Length
SamR is on a distinguished road
I am writing a code in Matlab that computes the velocity profile between 2 stationary parallel plates. Set up: steady, incompressible, laminar, 2D flow. Reynolds number of 100, based on a velocity inlet of 0.02m/s and channel height 0.1m. Density and viscosity corresponding to that of air. I'm using the SIMPLE algorithm on a backward staggered grid, with upwind differencing.
However I am finding that my development length is much too short. Based on the Reynolds number, and relationship L/D=0.5+0.05*Re, L/D should be around 5 - whereas I am seeing L/D of closer to 1. The profile of the fully developed region is in close agreement of the analytical solution, it just occurs earlier than it should do.
Any ideas on what might be causing this?
Thanks.
SamR is offline   Reply With Quote
Old   March 18, 2011, 14:08
JSoares is on a distinguished road
Hello
First let see if understand your problem:
Re=100
Air proprieties fluent: ρ=1.225 [kg/m3] and μ=1.7894e-5
Distance between plates = 0.1 [m] as 2h=0.1m
Solution:
Re=ρ*v*Dh/μ
Dh (Hydraulic diameter) = 4h = 0.2 m
So v= 0.0073037 [m/s]
You want de Le:
Le/Dh ≈ 0.06*Re
So Le/Dh = 6 m
Fluent:
Residuals: 1e-6
Iterations: 2000 (for example) – solutions should converge before 2000 iterations
Import Solution:
1) Create a line x=0 and y between -0.05 and 0.05 m
2) File-export-solution data…
a. Fyle Type: ASCII
b. Surfaces: chose the line created
c. Quantities: Chose x-velocity
d. Save it
3) Open excel
4) File-open-choose the file saved
5) Don’t forget to set separation comma to read the results
Cheers!
JSoares is offline   Reply With Quote
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
Yacht in Open Channel Flow andreimour FLUENT 1 October 14, 2010 23:54
PotentialFOAM for channel flow albcem OpenFOAM Running, Solving & CFD 0 October 16, 2008 12:18
VOF scheme for open channel flow yan FLUENT 1 May 21, 2005 00:21
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
