urgent help needed (rhie-chow interpolation problem)
Old   June 6, 2010, 15:43
Default urgent help needed (rhie-chow interpolation problem)
Ardalan
Ardalan is on a distinguished road
I've got a problem with rhie-chow interpolation. In the lecture notes this interpolation is used to calculate the mass flow rates which are used in the pressure correction equation. As we know a_p and velocity field from momentum equation solution, the implementation of this interpolation is straightforward.
As I understood the rhie-chow interpolation is used to calculate velocities at cell faces. In discretized momentum equations mass flow rates at faces are also needed to calculate a_p and a_nb (convective part of coefficients). Should we also use the rhie-chow interpolation for the calculation of mass flow rates for this case? If your answer is yes, the problem which remains confusing for me is on one hand a_p calculation needs mass flow rate to be known, on the other hand calculation of mass flow rate by rhie-chow interpolation needs a_p to be known. How can I solve this problem??
Ardalan is offline   Reply With Quote
Old   June 6, 2010, 18:26
Arjun
arjun will become famous soon enougharjun will become famous soon enough
use AP from last iteration, start with value of AP = 1.
arjun is offline   Reply With Quote
Old   March 18, 2011, 15:22
G. S.
gerardosrez is on a distinguished road
Hello Ardalan,
Just for curiosity, what kind of grid are you using? and is it a cell centred or a vertex centred scheme?
I tell you that I'm working in an unstrutured vertex centred scheme.
For your question I've read a lot about it and it's really confusing sometimes. In this case you need to remember the procedure to solve de convection - diffusion equation which is that you need the cell face velocity to know if the mass flow is entering or leaving the control volume because if you use an upwinding scheme (like I'm using) you're code then will fill the a_p or the a_nb coefficient with the mass flow value calculated at the control volume face.
In the case of momentum equation is the same thing, you need a cell face velocity to determine which coefficient will you fill with the mass flow value calculated at the face, this is to give more weight in the equation to the velocity value of the central node or it neighbours.
I propose you something give me you're email and let's share information about it, I have already developed a code in MATLAB not accurately working but I have gone far away i this subject. I'm sure we can help each other to get rid of this quickly
gerardosrez is offline   Reply With Quote
Rhie & Chow method/flame propagation? yang Main CFD Forum 0 May 19, 2005 08:00
Rhie - Chow Interpolation ? Javier Goicochea Main CFD Forum 0 November 27, 2003 18:01
Rhie - Chow speed up factors Goicox Main CFD Forum 0 November 22, 2003 00:00
Problem with interpolation Ramu Main CFD Forum 4 August 8, 2003 07:32
Problem with interpolation Ramu Main CFD Forum 0 August 7, 2003 03:37
