steady flow over airfoil
Old   June 12, 2010, 01:23
Default steady flow over airfoil
mahzad_kh
mahzad is on a distinguished road
hi dear all,I had simulated flow over eppler361 for different angles of attack for Re=94000 and v=10m/s, and I want to compare my results with naca0012 results and I need the pressure coefficient distribution around NACA 0012 for this Re or for Re<500000,I searched, but I couldn't find any useful results! do you have any data about it or do you know any site which I can find it? help me please!
Thank you for your kind attention!
mahzad is offline   Reply With Quote
Old   June 12, 2010, 02:49
nvtrieu is on a distinguished road
I'm doing simulation on NACA 0012, but I just only using experimental data at Re =3E6~9E6 that I got from "Theory of Wing Sections". I have not found any experimental data about Cp at Re<500000, but if you want to know the lift/drag coefficient you can see from the following links:
http://www.cyberiad.net/library/airf...ta/n0012cd.htm
http://www.cyberiad.net/library/airf...ta/n0012cl.htm
Trieu.
trieuckgt@gmail.com
msn:trieu.dut@live.com
YM:trieu_tme@yahoo.com
nvtrieu is offline   Reply With Quote
Old   June 12, 2010, 09:52
DoHander is on a distinguished road
You can use Xfoil to get a fair approximation of your 'missing' NACA0012 data.
Do
DoHander is offline   Reply With Quote
Old   June 12, 2010, 14:42
mahzad_kh
would you mind if I asked you to send your experimental data at Re =3E6~9E6 I think it can help me!I will really appreciated!
Old   June 13, 2010, 13:18
Hello mahzad,
Actually, I got experimental data in this book:"Theory of Wing Sections". So if you want to get it please give me your email!
My email: Trieuckgt@gmail.com
Trieu
Old   June 13, 2010, 14:01
Check this link (this NACA reports contains almost all the data presented in Abbott's book):
http://ntrs.nasa.gov/search.jsp?R=99...%257c1%26N%3D0
Do
Old   June 16, 2010, 01:56
mahzad_kh
Do
dear friend ,
I checked this link but it is about ''The basic equations of Timoshenko for the motion of vibrating nonuniform beams'' unfortunately I didn't find any thing related to my work in it! Are you sure it contains the data presented in Abbott's book!would you check it please!
thank you!
Steady state Ruben Main CFD Forum 43 May 7, 2011 03:32
initialize flow field with steady state solution holg FLUENT 0 July 13, 2009 17:10
How to determine whether flow is steady or unstead Maliya,Barth Main CFD Forum 7 October 7, 2006 02:26
Simulating flow past airfoil with different AOA Quarkz Main CFD Forum 2 January 6, 2006 10:56
Unsteady AND Steady mode for Fully Developped Flow Dominique FLUENT 5 April 16, 2004 17:58
