Help with convective heat flow
Old   June 21, 2004, 01:34
Default Help with convective heat flow
John Moody
Problem: A non uniformly heated sphere is placed in the center of a spherical cavity (~10 times the diameter of the heated sphere) with fixed wall temperature and the intervening space is filled with low to moderate pressure gas (1 to 300 Torr). The system is in a gravitational potential. The gas settles into a convective flow that looks something like a toroidal pattern.
Question: Is the code ANSWER or ANSWER express (from ACRi - I think) a good code for this? Is there something better that can be run in a few days? I'm not a CFD expert; my background is in physics. I'd like to model this quickly. Thanks -- John
Old   June 21, 2004, 16:51
Default Re: Help with convective heat flow
Jim_Park
One question is:
Does ANSWER allow you to include the radiative transfer?
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
UDF convective heat transfer correlations sarah FLUENT 0 March 29, 2007 09:52
Average Convective Coefficient (air) flow pipes chetansardesai Main CFD Forum 3 July 28, 2001 17:09
time averaged heat transfer in oscillating flow Matthieu Ubas Main CFD Forum 2 November 5, 1999 14:20
