-   -   Meshing software (http://www.cfd-online.com/Forums/main/77198-meshing-software.html)
pradeap June 16, 2010 07:52
Meshing software
Hi
I am using my own code to solve the problems like flow over cylinder and turbulent impinging jet. I cannot able to generate accurate meshing using my own mesh generator.
I am looking for a mesh generating software which should be easier to get the meshing details like connectivities and nodes after generating the mesh. so that i can use that information for my code.
MechE June 17, 2010 08:46
I personally use GMSH with COMSOL because of the output files. It has the ability to output NASTRAN and some other file formats. If you can understand the output files I am sure you can import it into your code. The program can be found here --> GMSH
