June 16, 2010, 12:38 |
Boundary layer thickness
Tomasz Merda
Rep Power: 15 |
Hi. I try to find a formula for boundary layer thickness for Re numbers 10e7 and higher. All formulas I find are for lower Re noumbers. Can anybody help me?
June 17, 2010, 04:15 |
Rep Power: 15 |
Can you post the equations that you have used thus far? So we know which ones you have and have not tried?
Cheers, T |
June 17, 2010, 08:21 |
Tomasz Merda
Rep Power: 15 |
i only use Y+ parameter in Fluent. In Gambit I set BL thickness "on eye". I find some equations but for Re 10e5-10e6. I have Re 10e7-10e8.
equation is delta=0,37*l/sqrt5(Re) |
June 21, 2010, 15:35 |
References
deja pong
Here is a reference that might be useful
http://www.desktop.aero/appliedaero/...yertheory.html Specifically: http://www.desktop.aero/appliedaero/blayers/lambl.html With an interactive applet where you can adjust the Reynolds Number: http://www.desktop.aero/appliedaero/...blsummary.html |
June 22, 2010, 07:58 |
Tomasz Merda
Rep Power: 15 |
Thanks
Now I must translate this |
June 22, 2010, 08:51 |
Rep Power: 19 |
I think you both make a confusion between the Boundary Layer (which is a physical model, specifically a simplification of the the Navier Stokes equations) and Gambit's boundary layer which is a geometrical entity.
What you probably need is an estimation for the height of the first row of cells at the wall in your mesh (the starting dimension in Gambit's boundary layer), you can estimate this for any Reynolds number using this calculator: http://geolab.larc.nasa.gov/APPS/YPlus/ It is unfortunate that Gambit uses the notion of boundary layer for a geometrical entity, but this has nothing to do with the Boundary Layer equation or theory !!! Do |
boundary layer thickness | Lee,jangho | FLUENT | 5 | January 5, 2017 10:03 |
Boundary layer thickness | ghazanfarzahedi | Main CFD Forum | 2 | July 28, 2009 23:43 |
Boundary layer thickness calculation | nat | FLUENT | 0 | April 9, 2009 06:04 |
plotting boundary layer thickness graphs in a 3d | Neelima | FLUENT | 1 | March 29, 2006 18:04 |
Boundary Layer Thickness | cfd-freak | Main CFD Forum | 3 | March 27, 2003 12:18 |
