dynamic meshing option
Old   June 24, 2004, 15:41
Default dynamic meshing option
arehman
HI, I am intrested to simulate a dynamic stall on naca 0015 using fluent 6.1.(dynamic meshing option).Is there someone who already has used this option ( DYNAMIC MESHING OPTION).IF so please guide me to make a mesh(since it has few particular requiremnts for moving portion ).Anything would be great.Thanks in advance
Old   June 25, 2004, 17:45
Default Re: dynamic meshing option
CFDtoy
For using the dynamic grids, make sure ur grid is fine enuf and the minimum volume of the grid should go on par with ur declaration in the dynamic mesh option.
Choose remeshing and follow Fluent instructions to initialize smoothing procedures.
Thinks should be ok !
And after all these, make sure ur time step is corresponding smaller than ur air foil motion !
Cheers
CFDtoy
Old   June 26, 2004, 03:59
arehman
hi, thanks for ur reply.Do i need to make a stationary or moving faces separately then interface them using non -conformable interface option. have u used this option ( dynamic mesh ) using fluent 6.1 becasuse i am facing problem in making mesh. thanks
Old   June 26, 2004, 13:50
CFDtoy
hello
I have used Dynamic Meshes in 3D and its more complicated in any 2D case since the time step has to be more than accurate.
I reckon you are working on a 2D case ( face moving ), jus make the face moving and you can read abt the non comformable interface in the Fluent manual ..if it is required for your case.
Jus make a moving face and run the code to see the grid motion.
Cheers
CFDtoy
Old   June 27, 2004, 02:55
arehman
hi, thanks for your reply.do i need to make the moveable(around the airfoil) and stationary faces ( inlet and outlet) and then hook them by using non -conformable option. or to make just one face ( entire domain including the airfoil). thanks for taking your time .
Fatal error Echidna CFX 4 September 13, 2016 05:50
CFX does not continue Shafiul CFX 10 February 17, 2011 07:57
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
Vessel Residence Time Distribution Help Davo CFX 3 December 19, 2006 03:36
about compresive phase James CFX 10 September 12, 2006 03:16
