reflection boundary condition?
Old   June 25, 2004, 18:01
Default reflection boundary condition?
cfdfan
Hi ,
I wanted to program a simple Euler equation solution for and airfoil using MacCormack scheme, for a supersonic case using finite difference method. I try to apply reflection at the wall (symmetry) without any results, using ghost points. I wanted to ask if it should be applied before the predictor or before the corrector step or both. And if yes, how. I simply could not figure out why the normal component of the velocity equals to zero when applying for 1 iteration.
I would appreciate any suggestion.
Old   June 26, 2004, 22:32
Default Re: reflection boundary condition?
versi
Since the intermediate step flow variable Q* has no apropriate physcial BC, but it must be consistent with original physical quantity. So I suggest in both steps of Macormack scheme, use reflection BC.
Old   June 28, 2004, 04:38
Bart Prast
Yep, your non-reflecting boudnary conditions have to follow the same loops as your 'internal' solution. If you would do it time accurate (say 2nd order) you would have to do the same time integration for your boundary conditions. From personel experience I can say that this really helps convergence. No more bouncing pressure wave going up and down the domain. To bad not more commercial codes have this feature. Did anybody do this in an implicit code?
Old   June 28, 2004, 04:41
Bart Prast
Oeps, forgot: If you have a fully supersonic case (in/outlet)then it shouldn't help you much as pressure waves do not travel upstream from your outlet and to your inlet. But do correct me if I'm wrong here.
Old   June 28, 2004, 10:14
cfdfan
Guys,
Thank You very much for all advices. However my confusion is the following. I am looking at the predictor and I do not understand why should the velocity component normal to the wall go to 0.0 if I set appropriate values at ghost points for a certain boundary.
Or should IC be set for the particular boundary appropriately in order to get reflection BC working?
Thanks.
Old   June 28, 2004, 12:53
M. Simpson.
What woudl be the difference and significance of doing this in an implicit code rather than an explicit code?
Thank you.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 02:37
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
