3D Interpolation
Old   July 14, 2004, 08:06
Default 3D Interpolation
Kyung-Seok, Kim
Hi! everybody. Now, I'm studying on 3D Multi-block method. But while I study above,I have some trouble. I hope you can help me.
Here is my problem.
There is 3D multi-block which consist of 2 block. and 'The bottom interface of upper block'(let's say B1) and 'the top interface of lower block'(B2) are NOT matched !
and I use FDM scheme,so I want to transfer potential information at grid point from B1 to B2.
and Now I try to use interpolation method.
Summarizing above thing, non-maching multi-block interface treatment of using FDM.
Q1)Is it right that I use interpolation like above problem?
Q2-1)If right,please recommend good reference,book and something like stuff.
Q2-2)If wrong,What am I gonna do ? ^^;
Thank you in advance.
I am waiting for your reply,Pro!
Old   July 14, 2004, 22:46
Default Re: 3D Interpolation
Halim Choi
Read following two papers given in the same journal issue : Numerical Heat Transfer: Fundamentals, Volume 32, Issue 4, December 1997
1.Computation of Unsteady Flows Using Non-Matching Blocks of Structured Grid by Lilek et al.
2. An Implicit Finite-Volume Method Using Non-Matching Blocks of Structured Grid by Lilek et al.
I had the papers, but I can not find them now. Thus I canot give you the detailed informations. I hope this helps you.
Good Luck
Old   August 17, 2004, 09:03
Default extreme points problem
Lipo Wang
Hello,everyone My problem is as follows: I have got the value of scalar at every grid point of a 256 cube and also have found these extreme points in this scalar field with a criteria of [S(i)-S(i+1)]*[Si-S(i-1)]>0, i should be in three directions: x, y and z. But we want more precise positions of these points, so interpolation is needed.
I tried to do interpolation and found some extreme points will dispear with the same criteria. This is due to the effect from no-adjencent points. For example, S(0,0,0) is extreme, then S(1,1,0), S(1,1,1),S(1,-1,0) are no-adjencent. So I wonder for interpolation, should I also consider these no-adjencent points, or only adjent points(totally they are S(0,0,1),S(0,0,-1),S(1,0,0),S(-1,0,0),S(0,1,0),S(0,-1,0))? Of course, more points considered, more reasonable. But more negative effect will destroy the criteria. How do you think about it?
Great thanks
Thread Tools
Trackbacks are On
Interpolation Error on FAM Mesh with Cyclic BCs ngj OpenFOAM Bugs 1 August 9, 2011 06:12
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 16:22
Help on 2D interpolation in StarCCM+ madhuri CD-adapco 0 November 3, 2010 15:21
Surface interpolation schemes and parallelization jutta OpenFOAM Running, Solving & CFD 0 February 25, 2010 15:32
momentum interpolation for collocated grid Hadian Main CFD Forum 4 December 25, 2009 08:25
