Turbulance Model
Old   February 3, 2011, 23:05
Default Turbulance Model
Vilok Srivastava is on a distinguished road
I am working on implementation of Turbulence Model "Spalartr Allamaras"
If any body know the discretization of convection term and best possible scheme to solve the derivative plz tell me
Vilok Srivastava
Vilok Srivastava is offline   Reply With Quote
Old   February 4, 2011, 18:51
Post Re:Turbulance Model
cfd_mistry_science
cfdpassion is on a distinguished road
Hi Vilok,
Spalart-Allamaras, model is one-equation turbulence model first used for aerodynaimcs. and i think for discretization of the convection term should be done with second order upwind scheme. if your problem is stady state then TDMA (Tri-diagonal-matrix-algo.) will be usefull and if transient flow then Forward-Time-marching solution will be usefull. and for pressure-velocity coupling you can use PISO algorithms or Transient SIMPLE methods.
cfdpassion is offline   Reply With Quote
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
