i need this header file sys/time.h
Old   July 21, 2010, 16:19
Default i need this header file sys/time.h
gholamghar is on a distinguished road
Hello
I need this header file for c++ : sys/time.h
can anybody send it to me?
Halgir3@yahoo.com
Thanks in advance
gholamghar is offline   Reply With Quote
Old   July 21, 2010, 19:43
DoHander is on a distinguished road
Hmmm, seems like you are trying to compile a Linux code on Windows. This header file won't be of any use, you will need the complete source code of the compiler in order to do something with this.
If you can describe your problem maybe I can help.
Do
DoHander is offline   Reply With Quote
Old   July 22, 2010, 00:36
I didn't know this header is for linux, i think you are right i have a code which uses sys/time.h and i am running it in windows and if sys/time.h is for linux i should run the code in linux. is there any header file similar sys/time.h for windows?
Old   July 22, 2010, 09:56
1. Your code already runs on Windows ?
2. In principle you can recompile a Linux code on Windows (if you have the sources) using Cygwin or Mingw.
Do
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
