Slow flow
Old   July 25, 2004, 07:38
Default Slow flow
Francisco
What is a good approximation for very very slow flow, a few mm per hour, in a transient stage? Low velocity in a fluid with density similar to that of water. Does any body know about publications on the subject?
Old   July 25, 2004, 08:44
Default Re: Slow flow
Rami
Is your Re small? If so, this is Stokes (or creeping) flow, where the convection term is negligible compared to diffusion. In this case the solution is much easier - since convection usually causes most of the modeling difficulties - and the equations become similar in form to the heat conduction equation. I am not sure what is the common threshold for the applicability of this simplification, though - I think it is Re<1, but you should check it for yourself.
Old   July 26, 2004, 17:57
Francisco
Rami. Thank you. Do you know any publication showing classical cases?
Old   July 29, 2004, 18:54
jenn
Use google and type "stokes flow", you will find tons of them and it is always discussed in traditional fluid mechanics books.
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 06:44
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Instability and Vortex/roll structure Z. Zeng Main CFD Forum 3 May 10, 2000 05:18
