Cobalt Job File
Old   August 18, 2010, 19:11
Default Cobalt Job File
andrew
monahan is on a distinguished road
Shot in the dark here...i'll email the cobalt guys tomorrow but i want to know tonight from home. Submitted my cobalt jobfile...successfully ran 2000+ iterations, converged just fine, results looked great. my turbulence model was spalart allmaras. Cobalt output a restart file every 100 iterations. Now i want to run an additional ~100 iterations using DES. set the job file to "restart file" and ran in debug mode to make sure everything went smoothly. debug job starts running, is able to grab the restart file, grid file, and BC file from the location i specified. I know this because i open up the running environment location and it is populated with all three files. however, the job dies a few minutes in and says "restart file not found. please check the file name in the input file".....
i dont get it....it clearly found the restart file because it brought it over to my workspace. the input file never asks for a restart file, only whether or not you are doing an initial run or restart. i am new to this, so i am undoubtedly doing something stupid. any thoughts?
monahan is offline   Reply With Quote
Old   August 19, 2010, 14:53
Default Run name?
Charles
CapSizer is on a distinguished road
Did you keep the runname and directories the same? Normally, as you say, this just works .... just edit the job file to say that it is a restart and it just goes.
CapSizer is offline   Reply With Quote
cobalt, job, restart
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
