Poisson equation vs continuity equation
Old   August 2, 2004, 09:51
Default Poisson equation vs continuity equation
DJ
HI all I am using poisson equaion and continuity equation to solve steady state Lid driven cavity flow problem With the two i am getting two different set of results..¿¿why?? both of them are principally same equations. With continuity equation I am getting oscillation(U, V and P also) with poisson equation , The results are numerically stable but the dont confirm the standard results also they dont satisfies continuity equation.. Any comment/suggestion/help.........Please..!!i am stuck!!
Old   August 5, 2004, 20:01
Default Re: Poisson equation vs continuity equation
jenn
I am confused. Continuity equation and the possion equation are different equations but related. You need to solve them at the same time to get u,v and P. Sometimes you have to iterate many times to make the continuity equation satified to some degree of accuracy.
The oscillation happens is maybe due to the numerical scheme you used.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
continuity equation Rafal Main CFD Forum 4 November 29, 2006 09:27
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
