Mass conservation
Old   July 29, 2004, 23:45
Default Mass conservation
Diego Nogueira
I deal with incompressible laminar flow (SIMPLE scheme).
For calculating mass conservation I add up the product A*V where A is the cross sectional area of a cell and V is it's velocity along a pipe. I perform the summation all over a cross sectional cut in a wind pipe.
Is there any other technique to verify mass conservation? What are reasonable mass conservation values? Always 100%?
Thank you.
Old   July 30, 2004, 15:50
Default Re: Mass conservation
agg
For an incompressible flow, the mass conservation condition reduces to a divergence free velocity condition. Hence you can check the divergence of velocity in your domain and see if it is zero. It won't be exactly zero. It should be small however, depending on the order of accuracy and boundary treatment.
Mass conservation in COMSOL Diego COMSOL 1 December 27, 2010 05:14
lost of mass conservation jjchristophe FLUENT 0 June 18, 2010 05:44
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 12:34
Mass Conservation in LES Sas Main CFD Forum 3 July 6, 2007 10:37
