-   -   wall boundary condition (http://www.cfd-online.com/Forums/main/7898-wall-boundary-condition.html)
woytex August 1, 2004 04:59
I am coding a 3D RANS/k-eps cfd code and testing 2D now. In the flow solver at the wall I set the normal stress tauxx=tauyy=0 and tauxy=tauyx=tauwall (tauwall is based on the wall low). Is it correct? Who knows, who has experience? Thanks. WX.
Jonas Bredberg August 19, 2004 07:11
Re: wall boundary condition
Hi there,
You may either implement the wall friction as a source term in the code as: tau_w*A, where tau_w=rho*u_tau*U*kappa/ln(9*y+) from the law-of-the-wall and A is the wall-area using this routine you should override the normal routines in the momentum equation
or through a modified eddy-viscosity as: mu_eff=rho*u_tau*y*kappa/ln(9*y+) and include that instead of the normal eddy-viscosity.
The normal stresses are very small at the wall as: tau_xx=mu*dU/dx tau_yy=mu*dV/dy for which both the velocity gradients and the (effective) viscosity are small.
Cheers Jonas
