Boundary Cond. in Supersonic flow
Old   August 9, 2004, 12:51
Default Boundary Cond. in Supersonic flow
Doctor Blade
Hello!
I'm using the conservative formulation programming my own code in Matlab, in order to solve a supersonic flow over a body. I'm using unsteady Euler equations and an aproximation time-dependent. But my question is How can I implement the bundary condition v*n=0 at the body surface?. Remember I'm using conservative formulation.
Thanks.
Old   August 9, 2004, 13:42
Default Re: Boundary Cond. in Supersonic flow
Takachi
Hi!
For supersonic formulation the Euler Equation is not good. Try the N-S formulation with the any turbulence model. This is necessary to a good convergence process. With Euler, in the surface, the velocity is zero, ok! You must attribute this value to all control volume locate in the wall.
Takachi
Old   August 9, 2004, 15:18
JF
If you haven't unknows on the body surface (like cell-centered formulation), one choice is to impose that the flux through your surface segment reduce to the pressure contribution, i.e.
Flux_normal_wall = [0 p*n_x p*n_y 0]^T
where n_x and n_y are components of the normal to the surface. p is the pressure extrapolated on the surface (with the method of your choice). It works rather well.
Hope this help
JF
Old   August 9, 2004, 19:49
Seb
Hi "doctor" Blade, before I can answer your question, I need to know the kind of spatial discretization that is being used (finite element with strong or weak formulation, cell centered FVM, vertex based FVM,...).
Old   August 10, 2004, 10:29
Doctor Blade
Thanks for your answers. JF, I do not understand why flux on the surface must be balanced with pressure.
Hi, Takachi, but I am going to keep the Euler formulation. I'm not an expert in CFD, so I think complete N-S formulation would be more difficult.
Hi, Seb, I'm seeking for solving with a finite difference method. (I think that Mac'Cormack steps in time would be sufficient). I'm using an structured elliptic grid, which external boundary is a circle of 10 times the characteristic body lenght. I'm going to try to explain all of you my method, in order to know your opinion.
i) I would start with some flow solution, rather arbitrarily. I would yield the freestream conditions on the external boundary in all instants of time.
ii) I advance with time steps of Mac'Cormack's algorithm, in order to be able to solve the transonic, subsonic and supersonic field that will be originated. But the problem I have is in the internal boundary condition.
What do you think?, Do you believe I'm going to be alive when I reach the convergence?.
Old   August 10, 2004, 12:57
ag
If you are using a finite-difference approach then the standard method is to compute the tangential velocity at the point adjacent to the boundary and project that to the boundary. Set the normal component to zero, and then transform those components to Cartesian or whatever coordinate system you are using.
Old   August 10, 2004, 15:28
Jarmo Monttinen
You should be able to get convergence rather quickly. Depends on how many bugs you will have in the code though...
I would use a "ghost-point" approach on the surface, ie. create an additional point inside the body. Then set the normal velocity (call it V) to zero by setting V(J-1) = -V(J+1) where J is the surface. Works well as long as your grid is sufficiently fine so that the ghost point is as far from the surface as the point inside the flow is. Use a similar approach for other variables, and you can actually solve the equations on the surface as well.
-- Jarmo
Old   August 11, 2004, 20:33
Seb
Hi Blade, Jarmo and Ag have given good enough info on the good approach on the implementation of the BC.
But in the order to solve your problem and get to convergence, you will also need a descent artificial dissipation scheme (Leer, QUICK,....).
Old   August 15, 2004, 15:06
Doctor Blade
Talking about this...
Does anybody know some website or paper in which I could see an example of procedure of this kind of simulation?.
I'm not searching for an advanced method, but one simple (e.g. Maccormack's).
Old   August 16, 2004, 02:47
Rami
Why not using Jameson's FVM, developed in the 80's? It is simple, well docummented and addresses the wall BC you asked about originally. You may find it in most textbooks, or go to the original papers (e.g., A. Jameson, Solution of the Euler Equations by a Multigrid Method, Appl. Math. Comput., vol. 13, pp. 327-356, 1983).
Old   August 16, 2004, 05:10
  #11
Bart Prast
It is about NORMAL velocity=0 (not a problem for Euler). Not TANGENTIAL velocity=0.
Depending on the spatial order of your numerical schema you can use 1 or 2 mirror cells. Worked fine for me
Old   August 16, 2004, 06:12
  #12
Doctor Blade
does FVM mean Finite Volume Method?. If so, I have no idea of FVM at all. I only know something about Finite Differences.
You know, the beginning is a hard time...
Old   August 16, 2004, 08:44
  #13
Rami
FVM indeed stands for Finite Volume Method. It is much simpler than you seem to imagine. I still suggest you to read the references I recommended or other introductory textbooks to CFD (e.g. Patankar or Ferziger & Peric).
Old   August 16, 2004, 16:26
  #14
Takachi
OK!
IŽll send to you the formulae about the wall boundary conditions.
My messenger is: takachi_e0028@hotmail.com
Wait my e-mail.
Regards,
Takachi
Old   August 17, 2004, 10:26
  #15
Doctor Blade
I've sent you an e-mail to both directions, telling you to write me to this other e-mail (see above).
thanks.
Old   September 6, 2004, 07:45
  #16
amit kumar khatri
sir,
i need to know how to compute fluxes for wall boundary conditions,inflow,outflow,far-field boundary. i'm using van leer fvs cell-centred fvm for my scheme.
Old   September 7, 2004, 13:37
  #17
Doctor Blade
Sorry, I've not used never FVM. But If I can help you, you must elaborate your question a little bit.
Thread Tools
Trackbacks are On
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 05:35
Flow Direction: normal to boundary!!! Atit CFX 1 August 2, 2015 13:42
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Boundary condition for not fully-developed flow John FLUENT 0 July 15, 2005 07:07
Boundary Layer Flow Paradox Wen Long Main CFD Forum 3 September 24, 2002 08:47
