May 6, 1999, 11:48 |
power-law scheme
Hi, I try to solve the energy equation. Central difference does not work(Pe in my proble is around 10,000). Now I want to try the power-law scheme given by the Patankar in his book. Has anybody tried this method? Is there a better way I can use? Thank you.
Lu Zhang |
May 6, 1999, 23:46 |
Re: power-law scheme
The power-law scheme at that Pe will give you the upwind scheme, that is assuming that Pe=density*velocity*dx/gamma. If Pe is greater than 10 at all points, you will end up using the upwind scheme anyway. I suggest you try that first.
May 7, 1999, 10:44 |
Hi, Thank you for your help. I will try that.
Lu Zhang |
May 8, 1999, 04:21 |
Hi, The central scheme is known to be unstable and is not recommended for high Pe numbers. The Power law scheme works fine. However I recommend you to use the first-order upwind and second order central difference hybrid scheme which is stable for several classes of flows and is also easy to implement. Regards
May 8, 1999, 15:13 |
Thank you.
Lu |
How to implement power law or hybrid schemes?? | kamkari | OpenFOAM Programming & Development | 13 | January 13, 2018 06:35 |
Non-Newtonian Power Law for Viscosity | John | FLUENT | 16 | September 12, 2015 06:18 |
Non-Newtonian Flow: Power law (2D BFS) | hellouch | FLUENT | 3 | April 21, 2009 03:03 |
POWER LAW DISCRETISATION SCHEME | Dammy | FLUENT | 6 | September 7, 2005 09:45 |
Non newtonian power law model in pipe annulus | Poly | FLUENT | 0 | March 24, 2005 15:12 |
