Flow in rotating pipe
Old   March 1, 2002, 03:00
Default Flow in rotating pipe
leon
Hello, I am trying to model the movement of gas or water in a straight pipe which rotates about its axis with constant rate. I have codes for modeling of flows with fixed walls but how to include rotation? Is this task non-stationary or I may use steady state code? Thank.
Old   March 1, 2002, 09:26
Default Re: Flow in rotating pipe
Patrick Godon
Hi Leon,
I guess you could solve your problem in the rotating frame of reference of the pipe, then the 'walls' of the pipe in this frame will be fixed. You will have of course to add additional terms to account for the effect of the centrifugal and corioilis accelerations. Whether the flow is in steady state or not might depend on the parameter of the problem (rotational speed, viscousity, ...). I guess that if the flow is laminar, the you probably will have a steady solution, where the time derivatives of the density, velocity and pressure will vanish. If you do have a problem with the additional Coriolis and centrifugal terms, I can try to help, and I am sure there would be other people in the forum who would help. I guess you are writting and solving the equation in a cylindrical coordinate system, with r, theta (or phi) and z, and the pipe is rotating around z. Am I correct?
Cheers, Patrick
Old   August 24, 2010, 01:42
Default rotating pipe flow
sathyan krishnan
krishns is on a distinguished road
I'm also facing similar problem. I want to derive an equation for exit velocity from a pipe rotating about an axis perpendicular to its axis. fluid under pressure P1 enters at the inlet. How I can calculate the exit velocity? considering the centrifugal force?
Kindly help me
Krish
krishns is offline   Reply With Quote
rotating porous media in a general flow a_dores FLUENT 0 October 31, 2010 04:50
Turbulence intensity in fully devloped pipe flow - Reference Shocktrain Main CFD Forum 0 October 14, 2010 06:58
flow in perforated pipe distributor pertupd ANSYS 0 August 12, 2009 08:36
Domain for Pipe Flow Swarup FLUENT 0 September 28, 2005 23:25
outlet boudary condition for a flow in the pipe Atit CFX 2 November 9, 2004 17:43
