August 19, 2004, 10:13 |
3D interpolation
Now I want to do parabolic interpolation in 3-D space Cartesian Coordiate. The form of parabolic should be: a0+a1*x+a2*x^2+b0*y+b1*y^2+b2*x*y+c0*z+ c1*z^2+c2*y*z+c3*x*z Totally 10 unknown coefficients. But for a cube, there are totally 8 end points. And if we also consider the information of 1st derivatives, then totally we have 32 known conditions. So the number of known coditions are not equal to that of unknowns. How to to this problem? Thanks
August 19, 2004, 11:01 |
Re: 3D interpolation
Try a local tensor product of Lagrange polynomials.
Regards, Markus |
August 19, 2004, 12:40 |
Hello,Markus Could you explain in more details? Lagrange polynomials is parobolic? What is the form of tensor you said? Thanks a lot Lipo
August 19, 2004, 13:54 |
You may want to consider a least-squares approach.
August 20, 2004, 02:12 |
1) 1d case.
Let the grid points be x_i, i=0,1,...,nx and the function values f_i = f(x_i) The Langrange polynomials L_p(x) depend only on the x_i (The L_p are of order nx. The definition of L_p should be found in any book about basic numerical mathematics.) and have the property L_p(x_i) = \delta_{ip} The interpolating polynomial then reads f(x) = \sum_{p=0}^nx f_p L_p(x) 2) 3d case. Cartesian grid points (x_i, i=0,1,...,nx), (y_j, j=0,1,...,ny), (z_k, k=0,1,...,nz), and function values f_{ijk} = f(x_i,y_j,z_k) You calculate the Lagrange polynomials L_p(x),L_q(y),L_r(z) and write for the interpolating polynomial f(x,y,z) = \sum_{p=0}^nx \sum_{q=0}^ny \sum_{r=0}^nz f_{pqr} L_p(x)L_q(y)L_r(z) You can apply this formula locally. I.e., e.g. choose nx=ny=nz=2 (quadratic polynomials) and consider the grid points (x_{i-1},x_{i},x_{i+1}) (y_{j-1},y_{j},y_{j+1}) (z_{k-1},z_{k},z_{k+1}) |
Display Modes | |
Help on 2D interpolation in StarCCM+ | madhuri | Siemens | 1 | May 30, 2017 04:20 |
Interpolation Error on FAM Mesh with Cyclic BCs | ngj | OpenFOAM Bugs | 1 | August 9, 2011 07:12 |
urgent help needed (rhie-chow interpolation problem) | Ardalan | Main CFD Forum | 2 | March 18, 2011 16:22 |
Surface interpolation schemes and parallelization | jutta | OpenFOAM Running, Solving & CFD | 0 | February 25, 2010 15:32 |
momentum interpolation for collocated grid | Hadian | Main CFD Forum | 4 | December 25, 2009 08:25 |
