thermal rejection limit of fluid
Old   September 6, 2010, 01:32
Default thermal rejection limit of fluid
mactech001 is on a distinguished road
Dear all,
in thermal-fluid analysis, is there a limit on the heat rejection by the fluid it can achieve please?
what theory, or parameter should i read on? conservation of energy?
i believe that, for a given amount of heat source, the fluid which has a fix flowrate and temperature flowing through cooling channel of fix dimensions is only able to reject a certain amount of heat from the heat source. As the heat source increases, the fluid can only reject a max. limit from the heat source and stay constant.
Look forward to hear of any comments/ideas.
Thank you for your kind attention.
Kind regards,
mactech001
Currently using: ANSYS v13
mactech001 is offline   Reply With Quote
Old   September 7, 2010, 17:32
Ahmed
Ahmed is on a distinguished road
Originally Posted by mactech001 View Post
Dear all,
Yes, there is a maxiumum, which is the amount of heat that a heat pump working in a Carnot cycle can transmit between the high temperature reservoir (the wall temp) and your sink, check your thermodynamics book for the definition
For the real amount of heat, it is a function of the Nusselt number, write down the definition and see what you can achieve.
Good luck
Ahmed is offline   Reply With Quote
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
