Looking for Periodic Tridiagonal Solver
Old   August 26, 2004, 17:20
Default Looking for Periodic Tridiagonal Solver
Wen Long
Hi, folks:
Can somebody post a code for Periodic Tridiagonal Solver?
Simply a tridiagonal equation Ax=b with tridiagonal elements and corner elements A(1,n) and A(n,1) non zero due to periodic boundary condition.
Thanks,
Wen
Old   August 26, 2004, 19:46
Default Re: Looking for Periodic Tridiagonal Solver
Tom
You should have a look at www.netlib.org. They have probably a solver.
Tom
Old   August 26, 2004, 22:29
Wen Long
Thanks, I think I figured out. Here is my subroutine:
Subroutine cyclic (alpha, beta,gama, b, x, N) !solve the following cyclic tridiagonal equation
!* (B1 C1 A1 ) (x1) (b1) *!
!* (A2 B2 C2 ) (x2) (b2) *!
!* ( A3 B3 C3 ) (x3) (b3) *!
!* ( A4 B4 C4 ) (x4)==== *!
!* ( A5 B5 C5 ) ... ==== ... *!
!* ( AN-1 BN-1 CN-1) (xN-1) (bN-1)*!
!* (CN AN BN ) (xN) (bN) *!
!************************************************* ************! ! where A are alpha, B are beta, C are gama c----dummy variables--
Integer N
double precision alpha(N), beta(N),gama(N),b(N),x(N) c----local variables--
double precision betaPrime(N),u(N),z(N),c,fact
c=-beta(1) !the minus sign makes sure betaPrime(1) non zero
betaPrime(1) = beta(1) - c !the first tirdiagonal element
do i=2,N-1,1
betaPrime(i)=beta(i)
enddo
betaPrime(N) = beta(N) - alpha(1) * gama(N) / c !the last tridiagonal element
call tri_ge(alpha, betaPrime, gama, b, x, N) !solve for x
u(1) = c; !first u,
do i=2,N-1
u(i)=0.d0
enddo
u(N) = gama(N) !last U is same as alpha
call tri_ge(alpha, betaPrime, gama, u, z, N) !solve for z
fact = (x(1) + alpha(1) * x(N) / c)
& / (1.0 + z(1) + alpha(1) * z(N) / c)
do i=1,N
x(i) =x(i)- fact * z(i) !construct final results
enddo
Return
End
Subroutine tri_ge(alpha,beta,gama,b, x, N) c----basically same as subroutine trig()----but allows diagonal variables not equal to unit
!* (B1 C1 ) (x1) (b1) *!
!* ( An-1 Bn-1 Cn-1) (xn-1) (bn-1)*!
!* ( An Bn ) (xn) (bn) *!
!************************************************* ************! ! where A are alpha, B are beta, C are gama c----dummy variables---
integer N
double precision alpha(N),beta(N), gama(N), b(N), x(N) c-----local variables
double precision betaPrime(N), bPrime(N)
double precision coeff
integer i
!Perform forward elimination
bPrime(1) = b(1)
do i=2,N
coeff = alpha(i) / betaPrime(i-1)
betaPrime(i) = beta(i) - coeff * gama(i-1)
bPrime(i) = b(i) - coeff * bPrime(i-1)
enddo
! Perform back substitution
x(N) = bPrime(N) / betaPrime(N)
do i=N-1,1,-1
x(i) = (bPrime(i) - gama(i) * x(i+1)) / betaPrime(i)
enddo
return
End
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 11:00
Question about the MIGAL solver bearcat Phoenics 0 February 4, 2010 18:02
block tridiagonal system solver for periodic bc Abdullah Main CFD Forum 8 February 23, 2007 13:15
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 07:09
Block Tridiagonal Solver Abdulhafid M. Elfaghi Main CFD Forum 2 December 23, 2006 12:20
