To plot a grid using Gnuplot
Old   September 3, 2004, 05:43
Default To plot a grid using Gnuplot
Jim
I have a 2-D unstructured grid for CFD calculations formed by triangles. I.e. there are two arrays: {i, x(i), y(i)} and {j, j1,j2,j3} where x(i),y(i) are coordinates of i-th node; j1,j2,j3 are nodes of j-th triangle. Is it possible to apply well known package Gnuplot (ver 4.0) to draw such grid and how to do this?
Thanks in advance.
Old   September 3, 2004, 06:44
Default Re: To plot a grid using Gnuplot
Tom
If you output your grid as
# First cell
x1 y1
x2 y2
x3 y3
x1 y1 # Second cell ...
where (x1,y1), (x2,y2) and (x3,y3) are the (consecuitive vertices of the triangle then gnuplot should be able to plot the grid with the usual plot command.
Old   September 3, 2004, 08:05
Jim
Thanks Tom, all works perfectly.
Jim.
Old   September 3, 2004, 10:16
krishna
Hi Tom,
The same question, in case i have a structured grid, with x,y co-ordinates for all the node points, GNU PLOT should be able to plot the same properly rt..
Plz confirm,
Thanks,
krishna.
Old   September 3, 2004, 10:35
Tom
You can do as I described above but using 4 points (which for a structured grid is a bit wasteful) or for each grid line in one direction ouput the (x,y) node values (remembering to inset a blank/comment line between each block) and then repeat in the other direction; i.e. if your node points are at x(M,N), y(M,N) then the file should look something like
# x direction
x(1,1) y(1,1)
x(2,1) y(2,1)
x(M,1) y(M,1)
# 2nd grid line
x(1,2) y(1,2)
x(M,N) y(M,N)
# Now y direction
x(1,1) y(1,1)
x(1,2) y(1,2)
x(1,N) y(1,N)
etc
Old   September 3, 2004, 16:32
amol palekar
i think if you use 'set dgrid3d then you may plot even non grided data. -amol
Making a grid from the XY plot mami FLUENT 2 October 18, 2009 23:53
Making a grid from the XY plot mami FLUENT 0 October 16, 2009 05:26
Vorticity plot in grid refinement study CH Main CFD Forum 3 May 22, 2007 12:35
how to plot isotherms in gnuplot? sivasamy Main CFD Forum 0 December 19, 2005 01:26
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
