Flat 2D surface immersed in 3D flow, is it possible?
Old   October 5, 2010, 12:39
Default Flat 2D surface immersed in 3D flow, is it possible?
César Vecchio
CAVT is on a distinguished road
Hello everybody.
This is my problem: I need to run a CFD simulation of a ventilation system, and the problem is that an important piece of the system is made from metal sheets. The only really problematic part is a metal sheet caping an extreme of an inlet with one of its edges free, and I cannot avoid its modelling so easily, but if I account for the sheet thickness it would lead to an unnecessary over refinement on that zone and maybe if I do it the run will not converge.
I would like to know if I can represent this sheet as a simple 2D surface, that is a flat shape with no thickness, and then set it as a wall. Both sides of the sheet are wetted by the flow. I plan to use Code_Saturne.
To show better my problem, please look at this picture http://www.absolutely-clean.com/cms_...hood_after.jpg. The sheet I'm referring too is the big square surrounding the extractor system (it's thin, don't get fooled by the bottom part which is a trough). It's not my geometry but rather similar.
Thank you in advance.
César
CAVT is offline   Reply With Quote
Thread Tools
Trackbacks are On
Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan Open Source Meshers: Gmsh, Netgen, CGNS, ... 3 October 22, 2015 11:05
Problem with Gmsh nishant_hull Open Source Meshers: Gmsh, Netgen, CGNS, ... 23 August 5, 2015 02:09
mapping flat surface to curve surface wei CD-adapco 2 June 26, 2009 08:10
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
Flow over surface Duncan FLUENT 0 January 26, 2006 12:05
