SIMPLE algorithm confusion
Old   October 6, 2010, 05:36
Default SIMPLE algorithm confusion
lost.identity is on a distinguished road
I'm wondering if SIMPLE algorithm is an implicit algorithm. I know that SIMPLE stands for semi-implicit method for pressure linked equations. In Patankar's book he describes that it's Implicit because the pressure correction effects on the neighboring velocities are omitted, so it becomes partially implicit.
However, my question is if it is partially implicit, then does it mean it's partially explicit. And if it's partially explicit does it mean that when you run the simulations you need to be careful of the time step size, like you are for fully explicit schemes?
Thanks.
lost.identity is offline   Reply With Quote
Old   October 7, 2010, 11:48
njenkins360 is on a distinguished road
I would assume if it's partially implicit, then the method has explicit behaviors, in which, yes, you would need to calculate a CFL condition, as the method is not unconditionally stable.
njenkins360 is offline   Reply With Quote
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
What is advantage of SIMPLE algorithm? Geon-Hong Main CFD Forum 1 May 18, 2010 07:46
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
SIMPLE algorithm Jonathan Castro Main CFD Forum 3 December 10, 1999 04:59
