Input leaks. 20 free element edges found.HELP Meshing Hypermesh |
October 18, 2010, 10:33 |
Pankaj
Iam trying to mesh a heat exchanger pipe with inside cylinder dia9.5mm , length 1200mm and outside cylinder dia 28.5mm and length 1300mm. 2d mesh is fine but while using 3d tetra mesh with cfd mesh its giving the above mentioned problem. The parameters for cfd mesh im using are
Total BL thckness-3mm First layer thckness-.5mm growth rate-1. Kindly suggest. |
Display Modes | |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
is free meshing or mapped meshing is best for flow problems | shanu | Main CFD Forum | 0 | February 18, 2010 11:58 |
[Other] is free meshing or mapped meshing is best for flow problems | shanu | OpenFOAM Meshing & Mesh Conversion | 0 | February 18, 2010 11:56 |
Meshing Ring Element | Jalen | ANSYS Meshing & Geometry | 2 | October 20, 2009 09:21 |
