Modeling Macroparticles in Microfluidic Channels |
September 17, 2004, 07:32 |
I am wondering if anyone has information on solid object (particle with real dimensions, mass, etc.) simulation in a fluidic domain. CFDRC has a macroparticle module under development, however, expected to be released mid 2005. Is there any other software that is capable to model the flow behaviour of real, single particles in microfluidic channels? Friction, gravity, interaction between particle and fluid as well as between particle and channel bottom and buoyancy should be considered by the appropriate software module.
Thank you in advance for your help. Daniel |
September 29, 2004, 19:50 |
Re: Modeling Macroparticles in Microfluidic Channe
Hi, I am also working on the particle dynamics of ferrofluids in microchannels. If you get a response, could you please inform me? If you can, it will be great! Thanks alot
Help needed on finding a good program for microfluidic modeling... | hamini | Main CFD Forum | 1 | June 30, 2009 00:14 |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 11:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
Solid Modeling | Chris | Main CFD Forum | 10 | July 2, 2002 07:12 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
