Require the fluid properties of the following fluids at different temperatures
I would like to require the thermal properties (density,specific heat,dynamic viscosity & thermal conductivity) at different temperature ranging between their freezing & boiling points of the following fluids listed below. This data is required for my M.TECH thesis.
1. ETHELENE GLYCOL 2. KEROSENE(RP 1) 3. ETHYL ALCOHOL 4. METHANE (these fluids should be in their liquid state for this application) Thanks in Advance :):) rohitjvbibin :D:D |
