Strcture of pressure correction equation in PISO stable over time ?
Old   October 26, 2010, 05:09
Default Strcture of pressure correction equation in PISO stable over time ?
sebi is on a distinguished road
Hello everybody,
I have a problem in understanding why the things I'm doing work. I'm using the PISO algorithm to solve the Navier-Stokes equations. In there I have to solve the Poisson-like pressure equation which I'm solving with an algebraic multigrid solver.
Unfortunatly my PISO algorithm does not use a real Poisson pressure equation like -/LAPLACE/ p= RHS, but it includes the flux a caused by this correction into the operator.
This is, I have - /DIV/ a /DIV/ p = RHS.
For the standard PISO with a real Poisson pressure equation it is pretty clear that the structure of the matrix resulting from discretising this will never change over the time steps. But how is this in my case ?
I see that the matrix' structure doesn't really change so I can use the AMG coarsening once and once again without giving a new setup. But this is too heuristic in my eyes.
So my question is: Can I argue from any physical point of view that the structure of my matrix stays as it is ?
Does anyone have an idea or a hint where I could read about this ?
KIndest regards,
Sebi
sebi is offline   Reply With Quote
Old   October 26, 2010, 22:19
N/A
harishg is on a distinguished road
PISO algorithm was a method proposed for pressure-velocity coupling of incompressible flows. There are many ways in which the algorithm has been used in the literature. Check the paper based on which the code was written. It might be a good starting point to understand.
harishg is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Pressure Correction Equation morteza OpenFOAM Running, Solving & CFD 2 September 4, 2007 06:16
