Clustering points in Elliptic mesh
Old   September 28, 2004, 11:06
Default Clustering points in Elliptic mesh
Doctor Blade
I'm programing in Matlab an elliptic mesh generator. But I've got problems when I try to cluster the iso\eta lines to the internal boundary. Some people told me about using force functions like:
P=A*sign(xi-xio)*exp(-B*(eta-etao))
to cluster the lines on some point (xio,etao). I DO not want to cluster any iso\xi line. So that, the value of xo has no sense for me. I'm only intending to cluster the iso\eta lines around the surface body (the internal boundary).
What function must I use instead of that given above?
Thanks in advance.
Old   September 30, 2004, 07:38
Default Re: Clustering points in Elliptic mesh
versi
check the book section Thompson's online-book about grid generation. It has clustering technique
Old   September 30, 2004, 08:29
Doctor Blade
It was just what I had done when I got into troubles. But it is not enough clear. I need some experience of people who have tried to compute something similar.
Old   October 16, 2004, 11:01
Angela Sunwoo
Hi, Doctor Blade
- Your point (xio, etao), not to be clustered, just can not be used. and no lines will not be clustered in the point. Just Dont use it !!!
- Your control function is similar with Thomson's one, I think. Thomson's are very good example, however, so many altinatives can be used... In my work, the full boundary control method is very robust one in structured grid. Of course, so many of the other functions are possible....
- If you want to know about them then e-mail me....
-Good Luck !!!
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
Points on surfaces in a rotating mesh Martin FLUENT 0 August 22, 2000 13:36
