need help on simulating flow over a cylinder
Old   November 23, 2010, 01:38
Default need help on simulating flow over a cylinder
beehuah is on a distinguished road
hi all,
need some advise and suggestion to start of for a project on flow over a bundle of circular cylinder. I'm using air as the working fluid with low reynolds number to get the nusselt number around the circular cylinder. Anyone can suggest me on the steps to start it.
thanks
beehuah is offline   Reply With Quote
Old   November 23, 2010, 03:05
srikanth
swamysrikanth is on a distinguished road
first of all, fix ur domain for ur simulation. that means cylinders position, alignment and so on. later try to make the fine mesh around the cylinders and some distance away from it in downstream zone to capture the flow.
then set up the case. run the simulation. compare the Cd and Nu with literature values.
before procedding do some literature survey it will give u a clear idea.
swamysrikanth is offline   Reply With Quote
Old   November 23, 2010, 07:17
kumar
pradeap is on a distinguished road
Is that Nu means Nusselt number...
i think you need to compare with the Strohals number along with the Cd
pradeap is offline   Reply With Quote
Old   November 24, 2010, 03:19
srikanth
yes it means Nusselt number.
you can compare Strouhal no. also with literature values
Old   November 24, 2010, 07:37
hi swamysrikanth
i have tried to simulate the bundle of circular cylinder with reynolds number of 100 but i got the Nu of 350 at the stagnation point of the cylinder. which is not reasonable.may i know whats the problem.
3D FLOW OVER A CIRCULAR CYLINDER Srinivas Mettu FLUENT 2 April 4, 2010 22:11
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
Flow around a cylinder at subcritical regime. yousef FLUENT 0 March 18, 2006 09:18
3D Flow over a circular cylinder Srinivas FLUENT 3 March 15, 2005 19:57
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
