fluid jet simulation with 1 dimensional equation
Old   October 8, 2004, 13:37
Default fluid jet simulation with 1 dimensional equation
sangwon
Hi All:
I'm in a computer graphics community and trying to simulate fluid jet. It's not in full 3D space. The axis is fixed, and need to see the change of the thickness of the jet along the axis while I perturb the velocity at the inlet position.
The requirement is 1. FAST & STABLE -- it should be realtime 2. need NOT be accurate -- if it 'looks' realistic, that's enough 3. should be able to handle the breakup without much hassle
I found a work by Jens Eggers who used 1D fluid equation to simulate drippling faucet. He derived the equation from NS equation in cylindrical coordinate. I actually got the source code from one of the authors, but it is too slow and complicated as a graphics application.
Can somebody give me a reference or advice?
Old   October 8, 2004, 14:46
Default Re: fluid jet simulation with 1 dimensional equati
Junseok Kim
You may want to the website, put your mouse on the jet figure, then you will see the movie.
http://math.uci.edu/~jskim/simulations.html
Junseok
Old   October 8, 2004, 14:51
Junseok Kim
sorry, I didn't read your post in detail, I missed some the calculation is slow and is not suitable to your case, what I meant is that it is not real time simulation.
Junseok
Old   October 8, 2004, 15:49
sangwon
But your simulation looks really cool! Did it use full NS solver or simplified 1D solver? Do u think it would be possible to simplify your code somehow to make it very fast? ( again, accuracy doesn't matter much )
Old   October 8, 2004, 16:31
Junseok Kim
The numerical code is solving full NS in axisymmetric domain (2D) and for the interface capturing I used phase-field model (Cahn-Hilliard equation), the basic idea is very similar to popular level set method. Jet simulation is complicated process, involving gravity, oscillating inflow velocity, and surface tension effects.
I am not sure how fast is fast in your case. The meaning of fastness is relative.
Junseok
Old   October 8, 2004, 16:34
Junseok Kim
As you may noticed from my simulation result, after pinch-off the droplet has inverted curvature, which is 2D effect, from the 1D you can't get that one because it has multiple solution from 1D point of view.
Junseok
Jet fan and Tunnel simulation ahlo7 CFX 9 November 13, 2019 04:54
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Source Term on Scalar Transport Equation - crashing simulation alessio.nz OpenFOAM 19 February 8, 2011 07:38
equation of state imbalance(engine simulation) hennie Siemens 1 July 4, 2002 03:21
