Fluid-Structure interaction
Old   November 2, 2010, 16:13
Default Fluid-Structure interaction
Pranav Ashtaputre
pranav_ashtap is on a distinguished road
I am modeling fluid-structure interaction. I want to know the pressure distribution inside a 3-D rectangular channel in following two cases. Without giving deflection to the top surface and by applying deflection function to the top surface.
Inputs are velocity(u,v & w) at the inlet, pressure at the outlet and no-slip conditions at the walls.
Ideally, how should be the pressure distribution on the top surface without any deflection?
Which software is recommended for this type of problem?
Any help would be appreciated.
Thanks
Pranav
pranav_ashtap is offline   Reply With Quote
Fluid Structure Interaction Apollo Main CFD Forum 5 July 4, 2011 16:15
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
Fluid Structure Interaction in Fluent Florian FLUENT 0 August 28, 2006 20:58
Fluid Structure Interaction Apollo FLUENT 8 July 7, 2004 17:54
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
